i got problems, input please!!!
boner
Post by boner »
stolle;53319 wrote:im gonna trace all the wires and make sure they are going to the right pin on the ecu so if anyone is free tonight feel free to shoot me a pm if you want to come hang out and trouble shoot the car i could always use an extra pair of hands... tia
All you have to do is call and ask you know this man.
Image ROHC THA SOHC
Post by stolle »
upon further inspection boner and i discovered that the voltage on the tps is a constant 4.97V regardless of its position. i tried a different tps and it did the same thing so im thinking my ecu got damaged somehow. so i may be in the market for a pm6 eventually :(
Team NOCO Crew Member #2
boner
Post by boner »
If you would like to use my ecu to see if runs any better you are more then welcome.
Image ROHC THA SOHC
Sleepy Civic DX
Post by Sleepy Civic DX »
i dont know about your car, but most tps sensors have three wires coming to them, a ground, a constant wire (usually at 5 volts), and a reference wire/meter wire that fluctuates with the butterfly, make sure you are testing the right one. if your tps sensor is reading a constant 5 volts, that would be wide open throttle wouldnt it? and your car would have trouble even idling, if it could even idle at all. Just double check and make sure you tested the right wire ( ithink you might be testing the hot wire). Just my 2 cents.
2009 Black Mugen Fit- Slow
boner
Post by boner »
Sleepy Civic DX;53556 wrote:i dont know about your car, but most tps sensors have three wires coming to them, a ground, a constant wire (usually at 5 volts), and a reference wire/meter wire that fluctuates with the butterfly, make sure you are testing the right one. if your tps sensor is reading a constant 5 volts, that would be wide open throttle wouldnt it? and your car would have trouble even idling, if it could even idle at all. Just double check and make sure you tested the right wire ( ithink you might be testing the hot wire). Just my 2 cents.
We tested all three thinking the some thing and for the idle it has a really jumpy one.
Image ROHC THA SOHC
Post by RyanA »
You didn't cross the MAP and TPS plugs, did you? They will both plug into each other...
Post by stolle »
tested all three wires in different combinations just like boner said rung them out all the way to the ecu tried two different tps'
RyanA;53628 wrote:You didn't cross the MAP and TPS plugs, did you? They will both plug into each other...
nope....
