Just because you can hear your blow off valve doesn't mean the car is in boost. If your blow off valve isn't adjusted properly or you have a cheap blow off valve it will go off when the motor is under vacuum.BlueDevil;150242 wrote:It does have a blow off valve which I can hear as low as 2500rpms. I wish I had all the original parts because I would just put them back on and then get the car tested, but I dont. I'm not ignoring everyone, a lot of the questions are going in circles. I just try to answer each post. Its really starting to look like I'll have to take out a loan and get a kpro put in, unless I can find a way to get an emissions waiver from the DMV...
Just do what I said (As well as everyone else) in my last post and you'll have no problem. Looks like your dead set on buying K-Pro anyway so go ahead and buy it.
