so I have had this turbo for a little bit now and have absolutely no idea what it is and really havnt done any measurements to it yet because i dont have a mic. The turbo is a garrett turbo for sure, has the optional external or internal wastegate setup, has the adapter piece that makes it like that along with going from a 5 bolt exhaust housing down to a 3 bolt exhaust housing. Its oil and water acceptable.11 exhaust fins, 12 compressor fins depending whats considered a fin or not.
Only thing on the turbo is .48 stamped on the exhaust housing and the cold side has been changed out it appears for a Polished Turbonetics Housing. Everything is garrett and air research stamped sides the cold side housing
Anyone got any good guesses, any help would be appreciated until I can measure and spec everything out
