OEM vs Aftermarket parts
getteg
Post by getteg »
So I found out my water pump is leaking so I am going to do the entire T-belt service along with a few other parts, and Im trying to decide if I want to go OEM or aftermarket for the parts. MY brain says OEM, but the pocket book says aftermarket.
Are the aftermarket componets for this going to live up to the OEM parts?
Im replacing the following
T-belt
Water pump
tensioner
cam seals
All other belts
Thermostat
I feel like Im forgetting something
Opinions please
Save a mouse....eat a pussy!
Post by Phate »
I'd buy the waterpump from Acura.
Get your timing belt kit from O'reillys, it will include the belt and tensioner. I rock gates belts and such.
Thermostat is whatever really.
getteg
Post by getteg »
Phate;243785 wrote:I'd buy the waterpump from Acura.
I was just reading a how to and noticed there is a tensioner spring. I assume that will be in the kit as well?
Post by Phate »
getteg;243786 wrote:I was just reading a how to and noticed there is a tensioner spring. I assume that will be in the kit as well?
I dont think it does.
http://www.oreillyauto.com/site/c/detai ... ponent+kit
But if you want to replace the spring, theyre cheap from Acura. $3.47.
EDIT: http://www.acuraoemparts.com/delray/jsp ... vinsrch=no
The spring is the same for LS, GSR, whatev.
fry
Post by fry »
get the water pump through carquest in the worldpac line, same exact shit as the dealer without the dealer price.
Post by andyjt »
fry;243788 wrote:get the water pump through carquest in the worldpac line, same exact shit as the dealer without the dealer price.
+1 GMB is the oem water pump supplier. Gates is the oem timing belt supplier as well.
getteg
Post by getteg »
Thanks for all the info gentelmen!
Peace
Brian
IshbOO
Post by IshbOO »
good info, im doing the same. oem water pump ftw
95 Silver JDM Fronted DC4 with B18c1 swap
94 Teal DC4
crimsoncivic
Post by crimsoncivic »
is the best place to get an oem throttle body for a d16y8 a junk yard? and how can u tell if its good? also how much do they cost?
