Bolt together exhaust system or custom bent and welded?
justme5424
Post by justme5424 »
Need a personal oppion on which is best? Looking to put togher a new exhaust system for my prelude? thanks in advanced guys.
90 Honda CRX HF
-B16A Turbocharged
Post by andyjt »
justme5424;94523 wrote:Need a personal oppion on which is best? Looking to put togher a new exhaust system for my prelude? thanks in advanced guys.
Whats you price range. Custom pieced together can be as good as an aftermarket one. Depends on the welder assembling it and how much effort they want to put into making it right. On the other hand, aftermarket ones now are pretty cheap for a decent brand.
justme5424
andyjt;94526 wrote:Whats you price range. Custom pieced together can be as good as an aftermarket one. Depends on the welder assembling it and how much effort they want to put into making it right. On the other hand, aftermarket ones now are pretty cheap for a decent brand.
I was thinking going with the A'pexi world sport, but wasn't sure if it would hold up to boost when I boost it later? Didn't want to go with a loud exhaust system on this one, goin JDM.
90 Honda CRX HF
-B16A Turbocharged
big pipe
Post by big pipe »
apexi is good stuff, get it if ya can
this space for rent
pr_tony_montana
Post by pr_tony_montana »
I have the apexi ws2 on my si and I love it... sounds good not ricey..
My99Si
Post by My99Si »
I like bolt on you can change out seperate pieces of your exhaust at home when ever you like.
B16inside
Post by B16inside »
like the genral concensous has been if the aftermarket fits your price range and if its quality work then jump on it.
i personally like my custom setup 2.25 piping with a passwordjdm test pipe and n1 muffler
but if you choose custom research the work of the shop youre thinking of so you know youre getting quality work. and its usually fairly reasonable in price range.
96 swapped dx coupe
B16inside
Post by B16inside »
justme5424;94529 wrote:I was thinking going with the A'pexi world sport, but wasn't sure if it would hold up to boost when I boost it later? Didn't want to go with a loud exhaust system on this one, goin JDM.
my friend richard has a ws2 on his sti and hes pushin around 17 psi so itll definatley hold up to boost:biglaugh:
96 swapped dx coupe
MaSSaCrE
Post by MaSSaCrE »
Boost=3inch
A little helpful info from Evans Tuning...
Evans Tuning wrote:All turbo cars should run a minimum of 3” downpipe, test pipe, and exhaust. Those looking to pass visual inspection should run a gutted 3” hi-flow cat.
All motor and supercharged b and d-series motors can run a 2.5” exhaust. A 3” exhaust is not necessary, but will not hurt power if it is used. All motor, supercharged, and nitrous k and h-series motors should use 3” exhausts.
We do not recommend catalytic converters on any turbocharged car. If you must run a cat to pass visual inspection, we highly recommend gutting the cat and essentially running a test pipe. If you come to a tuning appointment with a cat on the car and not hollowed and we suspect that it is creating a power loss, we can gut it for you, but it will not be done for free.
