Cable modem
SweetEBPSi
Cable modem
Does anyone have a cable modem I could borrow for a couple of days. My internet keeps going in and out and before I call them, I want to be able to tell them that the problem is on their end. Last time I had an issue, they said that it could be my modem going out. I want to bypass that stupid answer.
clndwhr
Cable modem
Question one...Is the modem itself getting hot? If so stand it on the end or side or elevate it with as much air flow around it and if it continues to cut in and out then try finding a spare modem. We had this problem and that solved it.
"Do you have an extension cord for the soldering iron?" -Me
"Uhhh.....I have a generator." -Andy
"Okay...." -Me
"Okay...." -Me
SweetEBPSi
Cable modem
Its not a heat issue. I've had this modem for years without any problems while being in the sun. Since it has started, the modem has been in the shade because the blinds are down and the air is on.clndwhr;58010 wrote:Question one...Is the modem itself getting hot? If so stand it on the end or side or elevate it with as much air flow around it and if it continues to cut in and out then try finding a spare modem. We had this problem and that solved it.
clndwhr
Cable modem
Hmm have you tried just plugging the computer directly to the modem? if you still have the problem then the modem is most likely the problem.
"Okay...." -Me
"Okay...." -Me
SweetEBPSi
Cable modem
Yeah. Tried that. I think I'll see if I can get my neighbors modem. She isn't there during the weekdays.clndwhr;58249 wrote:Hmm have you tried just plugging the computer directly to the modem? if you still have the problem then the modem is most likely the problem.
subygrl
Cable modem
SweetEBPSi;58376 wrote:Yeah. Tried that. I think I'll see if I can get my neighbors modem. She isn't there during the weekdays.
That won't work. Krystin needs internet so you can't take it.
2002 Subaru WRX-Pretty close to stock......for now
Potts1
Cable modem
If your new modem doesnt work, it might be a problem in one of the splitters. I was having the same problem, internet wouldnt stay connected then finally wouldnt connect at all. Got a new modem, still wouldnt connect, had a tech come out and replace one of the splitters and worked again.
-Potts
clndwhr
Cable modem
This could be as well the problem. Who is yoru cable provider? Charter? See if you can't have them bring out one of their test modems to see if that is the problem. Otherwise check all the splitters and if possible keep it down to one splitter between your incoming from outside and the modem.Potts1;58380 wrote:If your new modem doesnt work, it might be a problem in one of the splitters. I was having the same problem, internet wouldnt stay connected then finally wouldnt connect at all. Got a new modem, still wouldnt connect, had a tech come out and replace one of the splitters and worked again.
"Okay...." -Me
"Okay...." -Me
