Before:
After the first coat(still drying and not wet sanded)
First coat wet sanded
Next coat(fucked up thinned it down to much and had some deep scratches from wet sanding with to low of a grit.)
More to come as the day goes on
Want to to air brush some on?budget_crx;54914 wrote:for some reason i was expecting happy trees.
yes, make it a masterpiecebtlfedgolf;54915 wrote:Want to to air brush some on?
Kolk1;54926 wrote:You see in the close up pic of the wet sanding, how some looks white, while other deep spots are still black. Keep wet sanding.
That part should of been taken care of during priming. You shouldnt have bumps like that with only one coat.
I normally wet sand till perfect during primer.
4 coats of paint, then wet sand, then clear coat.
