My first try at painting.
Well I decided to take my spare hood and try my hand at painting.
Before:
After the first coat(still drying and not wet sanded)
First coat wet sanded
Next coat(fucked up thinned it down to much and had some deep scratches from wet sanding with to low of a grit.)
More to come as the day goes on
g3integragsr
Post by g3integragsr »
not to shabby, good luck on the rest
Post by budget_crx »
for some reason i was expecting happy trees.
budget_crx;54914 wrote:for some reason i was expecting happy trees.
Want to to air brush some on?
btlfedgolf;54915 wrote:Want to to air brush some on?
yes, make it a masterpiece
It looks good post up when your done.
JZO6ETR
Post by JZO6ETR »
Looks pretty good zach,not bad at all for the first time!
Bitch I Might Be!
More pics added of the next coat
Kolk1
Post by Kolk1 »
You see in the close up pic of the wet sanding, how some looks white, while other deep spots are still black. Keep wet sanding.
That part should of been taken care of during priming. You shouldnt have bumps like that with only one coat.
I normally wet sand till perfect during primer.
4 coats of paint, then wet sand, then clear coat.
Kolk1;54926 wrote:You see in the close up pic of the wet sanding, how some looks white, while other deep spots are still black. Keep wet sanding.
Thanks for the advise...like I said, this is my first try.
Any other advise from anyone else is very welcome.
I will most likely knock it all back down with the orbital after this coat dries.
