rear sway bar problems
CourtesyFlush
got new blox LCA's and the rear sway bar doesnt fit up to it. i got a GSR. what do i do?
In waht way isnt it fitting? Is it even close? Have you called blox to make sure you got the correct part number?
Theyre not intended to be used with the stock endlinks, or a stock swaybar for that matter.. but you can make it work. You just gotta buy some high grade long bolts and nuts, pull the endlinks until they line up and shove the bolts in. I did it, and it works fine.... so far.
Midori
yeah the sway bar mounts at the top of the LCA stock where as most aftermarket LCAs make it mount in the center of the LCA if you buy skunk2's or Function7's you wont have this problem other wise do what phate said or buy an aftermarket or type R rear sway bar and get the proper endlinks
-'11 Taffeta White CR-V
CourtesyFlush
ok thanks. and until then, if i dont connect the sway bar and just use my car as a dd, it wont hurt nothin will it??
lol. no it wont. will jsut drive even shittier than it did before.
on a side not. my stock endlinks bolted right up mine...........
