I am throwing: P0131 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage
I have checked the connection and it is fine. I have also tried another primary o2 and it still throws a check engine. What else do I need to check for?
Please help!!
SnailFed
LowePerf
Model,Make,year? engine size?
618-463-0224
618-463-0224
JesSi
It's a 96-00 Honda Civic, 1.6L or 1.8L I think.LowePerf;115104 wrote:Model,Make,year? engine size?
SnailFed
It is a 2000 Honda Civic EX. d16y8. I can't pass emissions b/c of this damn check engine. Is it possible that I have a bad primary o2 sensor even though I have tried another one?LowePerf;115104 wrote:Model,Make,year? engine size?
Is that the code that normally comes up if it is a bad o2 or is that something else?
Thanks for the replies!
SnailFed;115163 wrote:It is a 2000 Honda Civic EX. d16y8. I can't pass emissions b/c of this damn check engine. Is it possible that I have a bad primary o2 sensor even though I have tried another one?
Options :
- Other o2 sensor you tried is bad.
- too high resistance in the wiring (o2 signal wire)
- short to voltage in the ground side of the sensor.
______________________
-Id double check the connectors.. ( Could be corroded/ water in them . - Possibly use electrical contact cleaner)
-Check Ohms of Signal wire (White) --> (look at pinout) http://www.ek9.org/forum/other-technica ... -obd1.html
-Check for shorts from O2 sensor ground to Power (battery) - A test light would work fine.
Hope this helps
-Andrew
