Scratch at high rpms going into 4th and 5th.
2ksi
I dont know what is wrong with my trans but it scratches going from 3rd to 4th at about 3-4k RPM's. When i have it in N and rev it to 3.5k RPM's and put it into 4th it doesnt scratch. I dont know anything about transmissions but i was told to test my syncros by double clutching but i dont think that proved anything for me. There are literally no miles on the car too. 35k miles. Any advice?
00 civic si
**fuck playboy there's honda tuning for a reason**
haha
ryan will say what the problem is.
Sounds like you probably have a bad synchro spring right now. If it's not been doing it for long, it will probably be a fairly cheap fix. If you wait, you'll probably end up needing a 3-4 sleeve kit and a 4th gear.
2ksi
Oh okay. It started doing about 2 weeks ago, when it started getting really cold. How would i test it?
00 civic si
PM'd you about what I'd do. that may or may not fix it. It's worth a try.
2ksi
Ha, im so lost man, what? =PRyanA;216387 wrote:Right above your post... LOL
00 civic si
You asked where I (Ryan) was and I said right above your post. I'm the Ryan Dale is talking about...
2ksi
Oh, i edited that post to some else when i saw that you already posted something lol.
00 civic si
same thing i was gonna say.RyanA;216385 wrote:Sounds like you probably have a bad synchro spring right now. If it's not been doing it for long, it will probably be a fairly cheap fix. If you wait, you'll probably end up needing a 3-4 sleeve kit and a 4th gear.
fix it now and it will be really cheap, if you wait it will be really expensive.
i can fix it for $80 + the spring.
2ksi
PM sent mike.
00 civic si
