gear grinding
01luder
gear grinding
when i try to shift quickly at a high rpm from 2nd to third only i hear and feel a slight gear grind why only in third and what is the cause ? any ideas?
gear grinding
because your 3rd gear synchro is trashed01luder;143092 wrote:when i try to shift quickly at a high rpm from 2nd to third only i hear and feel a slight gear grind why only in third
Honda sucks at 3rd gear synchros.01luder;143092 wrote: and what is the cause ? any ideas?
gear grinding
and also expect the syncro spring, syncro hub, and dogteeh on the gears to be trashed...unless it JUST started grinding and youre getting it fixed before you grind it anymore.Spork;143098 wrote:because your 3rd gear synchro is trashed
negative! syncros are all the same no matter which gear. the little honda racers just dont know how to properly drive.Spork;143098 wrote:
<------ never once had a grinding gear ever in any honda ive owned (ive owned MANY)
Silver Knight
gear grinding
is that so....mike93hatch;143112 wrote:and also expect the syncro spring, syncro hub, and dogteeh on the gears to be trashed...unless it JUST started grinding and youre getting it fixed before you grind it anymore.
hmmmmmmm........mike93hatch;124300 wrote:the only maker i know of is gearspeed.
and they dont do anything anyways, not worth it. stock syncros are fine.
i had them once and all they did was make me grind gears.
DC5
gear grinding
Ownage.
You can say that Honda syncros are not the problem, but Honda's second and third gears are junk. Theres a reason why all post 2001 Honda and Acura 6-Speeds have a TSB on 3rd gear grinds. Ask any RSX-S owner.
gear grinding
x2, EP3s have the same issue. as do the new si's.SilverStreak;144299 wrote:Ownage.
gear grinding
hhaaha i thought about that when i posted that.Silver Knight;144286 wrote:is that so....
hmmmmmmm........
i meant oem honda syncros not junk ass gearspeed stuff. the carbon coating made it very hard for the syncro to move at all so they grinded from the very get go and a few hundred miles later and said fuck them. cool points for you though!!
gear grinding
and again im not talking about newer hondas.. if you ever notice i never talk about newer hondas. im stricly a 2000 and older guy.SilverStreak;144299 wrote:Ownage.
guess i need to add alot more specifics to my posts next time.
gear grinding
Speaking of specifics, the OP should probably disclose exactly what trans they are having issues with. One may assume that they have an 01 Prelude but with all these people talking of K series trannies, I am thinking they know something we don't. If it is a lude, all the talk of K series trannies is pretty much null and void since it's a totally different trans. Apples to apples.....
Not ALL Honda synchros suck. B series VTEC's have dual 2nd gear synchro. CTR/ITR have multiple dual synchros.
Ryan
Ryan
