So I just got my GSR back after not having it for a month and a half and I drove it hard a bit and the clutch started to slip a bit under acceleration. At this point I realized that when they put the motor in my car I had them do a clutch and flywheel and by driving it hard I completely fucked up the break in. I just wanted to know if I'm screwed or if I just take it easy for 500 miles or so it will sort its self out.
Thanks
Sean
Clutch and Flywheel Break in
UMR Racer
CARS
1994 Civic EX SOLD
2001 Acura Integra GSR
1994 Civic EX SOLD
did you get the flywheel turned? that could be the problem.you should be fine mine was broken in after like 200 miles. are you sure it was not your tires slipping?UMR Racer;104170 wrote:So I just got my GSR back after not having it for a month and a half and I drove it hard a bit and the clutch started to slip a bit under acceleration. At this point I realized that when they put the motor in my car I had them do a clutch and flywheel and by driving it hard I completely fucked up the break in. I just wanted to know if I'm screwed or if I just take it easy for 500 miles or so it will sort its self out.
Thanks
Sean
UMR Racer
No its a brand new Exedy Stage One Clutch and a ACT Streetlite Flywheel. Maybe they got some oil on the fly wheel during instal. It definatly wasn't the tires.
CARS
1994 Civic EX SOLD
1994 Civic EX SOLD
never broke a clutch in before in my life and never had any problems.
:bouncy::kermit::demon::music3: oh yea, me toomike93hatch;104219 wrote:never broke a clutch in before in my life and never had any problems.
UMR Racer
so is the slipping from the smoothness of the new flywheel surface or oil on the wheel.
CARS
1994 Civic EX SOLD
1994 Civic EX SOLD
UMR Racer;104222 wrote:so is the slipping from the smoothness of the new flywheel surface or oil on the wheel.
that first thing you said made me laugh, most likely with the second thing. i have the same clutch, are your double clutching?
the second thing you said makes me laugh.matt;104451 wrote:that first thing you said made me laugh, most likely with the second thing. i have the same clutch, are your double clutching?UMR Racer;104222 wrote:so is the slipping from the smoothness of the new flywheel surface or oil on the wheel.
you gotta be double clutching like you should!!!!!
me personally..... i triple clutch!!!
