i was wonder ing if anybody knew if the prelude axles(92-96) will fit in a my 94 accord
the main deal is the length of it from the trany to the hub didn't know if they were longer or shorter
i know that the tranys will fit already swaped trany and swaped back after turboing my car
prelude axles?
prelude axles?
94 accord axle
95 prelude axle
they have different part numbers which means they are different parts. i would say no.
95 prelude axle
sloaccord20
prelude axles?
alot of time the only reason they have a different part # is that it is for a different car but not all the time
prelude axles?
different part numbers means different parts. the same part number means its the same part.sloaccord20;95171 wrote:i've alot of time the only reason they have a different part # is that it is for a different car but not all the time
sloaccord20
prelude axles?
and i know that the half shafts are different on the axle input
an abs and non abs have a different part number but they both work in my car since i don't have abs
thats why i'm just sayin because they have a different part number doesn't mean that they won't work or fit
big pipe
prelude axles?
ive been reading about that, the prelude axles are about 1/4" longer than the accords. they WILL work. they just stick out of the hub a little:sign17:
make sure you stay auto to auto, or manual to manual, youll be fine
this space for rent
96civic cr-v
prelude axles?
what happen tony did u break another one???
sloaccord20
prelude axles?
big pipe;95191 wrote:ive been reading about that, the prelude axles are about 1/4" longer than the accords. they WILL work. they just stick out of the hub a little:sign17:
thanx thats what i was wanting to know
96civic cr-v;95193 wrote:what happen tony did u break another one???
not yet just been looking for axle swap that will be a little stronger than what i got and not spend 500 or more
ls1slayer
sloaccord20
prelude axles?
yes and i heard that they aren't very goodls1slayer;95236 wrote:$500 is that drive shaft shop axels?
