prelude axles?
sloaccord20
prelude axles?
Post by sloaccord20 »
i was wonder ing if anybody knew if the prelude axles(92-96) will fit in a my 94 accord
the main deal is the length of it from the trany to the hub didn't know if they were longer or shorter
i know that the tranys will fit already swaped trany and swaped back after turboing my car
prelude axles?
Post by rickles8099 »
94 accord axle
95 prelude axle
they have different part numbers which means they are different parts. i would say no.
sloaccord20
prelude axles?
alot of time the only reason they have a different part # is that it is for a different car but not all the time
prelude axles?
sloaccord20;95171 wrote:i've alot of time the only reason they have a different part # is that it is for a different car but not all the time
different part numbers means different parts. the same part number means its the same part.
sloaccord20
prelude axles?
and i know that the half shafts are different on the axle input
an abs and non abs have a different part number but they both work in my car since i don't have abs
thats why i'm just sayin because they have a different part number doesn't mean that they won't work or fit
big pipe
prelude axles?
Post by big pipe »
ive been reading about that, the prelude axles are about 1/4" longer than the accords. they WILL work. they just stick out of the hub a little:sign17:
make sure you stay auto to auto, or manual to manual, youll be fine
this space for rent
96civic cr-v
prelude axles?
Post by 96civic cr-v »
what happen tony did u break another one???
sloaccord20
prelude axles?
big pipe;95191 wrote:ive been reading about that, the prelude axles are about 1/4" longer than the accords. they WILL work. they just stick out of the hub a little:sign17:
thanx thats what i was wanting to know
96civic cr-v;95193 wrote:what happen tony did u break another one???
not yet just been looking for axle swap that will be a little stronger than what i got and not spend 500 or more
ls1slayer
prelude axles?
Post by ls1slayer »
$500 is that drive shaft shop axels?
sloaccord20
prelude axles?
ls1slayer;95236 wrote:$500 is that drive shaft shop axels?
yes and i heard that they aren't very good
