weird vtec timeing help!
lil_italy
Post by lil_italy »
i just bought a 98 civic ex with a d165y. the issue im havin is that my vtech is kicking in at 5500 rpm and not 4300-4500 rang. it make the car poopy slow untill vtec kicks in then its a hole nother beast. but also im having a idle surge at 1600 rpm . iv changed idle corntrol valve, tps, cleaned everything and still nothing. dose anyone have an idea wat could be going on ie computer or other sensor issues? the surge is only at 1600 rpm with little bit of throttle. wat do i check next
Are you using the P2N ECU for the D16Y5?
delslo
Post by delslo »
My Vtech kicks on when I tap the on button...
lil_italy
Post by lil_italy »
not to sure i opened it up and was looking to see if it was chipped but it dont have any were to put a chip in seems like
its prolly the y5
lil_italy;283093 wrote:not to sure i opened it up and was looking to see if it was chipped but it dont have any were to put a chip in seems like
its prolly the y5
There should be a tag on the side of the ECU. It should have a part number reading 37820-xxx-xxx. What are the letters and numbers in the 'x' spot?
lil_italy
Post by lil_italy »
its 37820-P2P-A81
Post by HardCore97 »
that is the original stock EX ecu then
Racecore.com
lil_italy;283136 wrote:its 37820-P2P-A81
Yep, that's the wrong ECU. The D16Y5 is a pretty unique engine design and the matching ECU is a must have item. Is the car automatic or manual?
Edit: I assume an automatic based on your current ECU part number. Is that correct?
lil_italy
Post by lil_italy »
manual but i just got a 94 preude with the h23a1 im prolly gunna drop in it.
lil_italy
Post by lil_italy »
i would never buy an automatic civic
