90 crx hf d16z6 w/ hf trans- header, short ram, exhaust no cat
my timing belt has slack. while rotating the crank to check the timing the belt would tighten and slack back out. as if one side tight other side loose. is the belt streched? i do have a new gates belt on standby.
my other question is: i noticed my car running rich. im having random idle surges, only getting 220 miles per tank, and a blatent fuel smell with smoke from exhaust. ive checked for vac leaks and fixed what i found, installed new plugs, wires etc, fuel filter, o2. any ideas on where to go next? also there are no cel codes.
crx issues
crx issues
Try adjusting the tension first. With the engine cold, remove the valve cover and upper timing belt cover. Set the No. 1 piston at TDC. Loosen the timing belt tensioner adjusting bolt 180°. Rotate the crankshaft counterclockwise 3-teeth on the camshaft pulley to create tension on the timing belt. Make sure the timing belt and the camshaft pulley are engaged securely. Torque the timing belt tensioner adjusting bolt to 33 Ib-ft. After adjusting, retorque the crankshaft pulley bolt to 134 Ib-ft.
Always rotate the crankshaft counterclockwise when viewed from the pulley side. Rotating it clockwise may result in improper adjustment of the belt tension.
If the timing belt still has excessive slack, I would remove the timing belt and timing belt tensioner and inspect them for wear.
As for the poor fuel economy, what ECU are you using? When you fill up after driving 220 miles, how much fuel are you putting in the tank to bring it back to full? Do you still have the FITV, Charcoal Canister and Purge Solenoid?
91beatuphatch
crx issues
fitv is still there and charcol canister and purge solenoid have been bypassed. and i know my gas guage is off about a gallon or so. i think i usualy put 8 gallons in it. ecu is p28.
gcef89
crx issues
try cleaning your iac and fitv they can cause idle surges. and are u smelling the fuel smell inside of your car? or out by the exhaust?
CRX91
crx issues
The gas gauge is like 2 1/2 gallans off I for got to tell u that
91beatuphatch
crx issues
it doesnt seem that far off but i knew it was. and i smell gas from exhaust. with a little smoke at idle. people behind me while driving say they smell it from a distance.
CRX91
crx issues
I did tell u that it has the obd0 injectors and u should swap it to the obd1 injectors that mite help some of the lacking power problems ur having
91beatuphatch
crx issues
yes you did but i was wondering if i put obd1 injectors in wouldnt i have to bypass the resistor box? im lost with it.
CRX91
crx issues
Yea I think you would have to but I'm not 100% sure
