help
CRXFreak
help
ok well i have my lsvtec in and everything hooked up but for some reason the injectors arent working, i have the right injectors. im pretty sure all my grounds are hooked up, 1 from the valve cover to the chassis, 1 from the starter to the chassis and one from the battery to the chassis, and the one on the thermostat housing, if im missing any please let me know where they are supposed to go. i know its getting fuel into the fuel rail. the timing is right as far as i can tell everything is hooked up and all the fuses i have checked are good. any ideas on what this could be would great.
help
Check for power and the injectors in the Run position and when cranking...CRXFreak;157376 wrote:ok no i dont have a dmm and what am i supposed to be checking for voltage
help
CRXFreak;157556 wrote:just as i thought there is NO power getting to the injectors
Do you have all of the ecu connectors plugged in?
3-at the ECU
1- green plug to the body at the ECU
1- at the drivers side of the car?
