Homemade turbo setup....
HondaChild
What are some of the things over looked when people build and create turbo setups? Any tips and or advice would be appriecaited. This isn't for my car, its an 87' Acoord LX-i.
Know your roots.
Bracing of the downpipe, possibly the bracing of a turbo. Wastegate placement on the manifold.
Are you talking about piecing a setup together or pretty much making it?
risktypes
The most one i have seen A LOT that people overlook is the size of the turbo. They think bigger is better, but if your motor doesn't flow enough CFM your not spooling that damn turbo until 2nd gear 3-5k. I have seen it over and over and over. I have seen people get turbos that are too small for their motor. There's just a bit more to sizing a turbo then just buying one.HondaChild;137458 wrote:What are some of the things over looked when people build and create turbo setups? Any tips and or advice would be appriecaited. This isn't for my car, its an 87' Acoord LX-i.
myspace.com/jinlee
myspace.com/jinlee
HondaChild
Well it will be a junkyard setup but it has to be a custom manifold, charge piping etc. But one of my big things are how would you control fuel and that stuff on an 87 OBD0 car?5thgen;137463 wrote:Bracing of the downpipe, possibly the bracing of a turbo. Wastegate placement on the manifold.
Know your roots.
-turbo edit http://forum.pgmfi.org/viewforum.php?f=60HondaChild;137479 wrote:Well it will be a junkyard setup but it has to be a custom manifold, charge piping etc. But one of my big things are how would you control fuel and that stuff on an 87 OBD0 car?
or
- uberdata http://en.wikipedia.org/wiki/Uberdata
i think are obd0
but as far as what parts are over looked .. tuning,fuel and compressor maps
but if you stick to a turbo like a 14b or t25/28 it should fit your application fine
big pipe
truman001
You can just use a missing link and fmu. Just run a high flow fuel pump. It should be good for a while.HondaChild;137479 wrote:Well it will be a junkyard setup but it has to be a custom manifold, charge piping etc. But one of my big things are how would you control fuel and that stuff on an 87 OBD0 car?
whatever you do DON't listen to this type of advice .. the FMU is cave man fuel management, and a missing link seriously.truman001;138506 wrote:You can just use a missing link and fmu. Just run a high flow fuel pump. It should be good for a while.
lol. Hoosier.truman001;138506 wrote:You can just use a missing link and fmu. Just run a high flow fuel pump. It should be good for a while.
