where the does the vacuum line thats laying on the intake mani go? i know on my old y8 it went on the back bottom corner of the IM but on the new b18b i cant feel it or see it anywhere. anyone know where it goes?
SOLD!!!!!!it is hooked up to a diaphram. basically the vacuum will pull the diaphram shut and it will in turn pull on an extra throttle cable either connected to the gas pedal or near the throttle body. it will only pull the cable a little bit. when cc is on and your cruising it has a little tension on the cable allowing you to maintain speed. when you go up a hill it will sense more engine load (or vacuum). it will then pull the cable, opening the throttle body just enough to keep your speed.94civicoupe;99949 wrote:why is there a vaccum type hose for cruise control, whats it's function????
SOLD!!!!!!
