where does this go?
where does this go?
Post by HardCore97 »
where the does the vacuum line thats laying on the intake mani go? i know on my old y8 it went on the back bottom corner of the IM but on the new b18b i cant feel it or see it anywhere. anyone know where it goes?
94civicoupe
where does this go?
Post by 94civicoupe »
have you checked the iacv
Image SOLD!!!!!!
v-tecivic
where does this go?
Post by v-tecivic »
that line is from the cruise control. if you dont have c/c anymore i would just take it out. otherwise if you're putting the c/c back up you could probably just T it off the brake booster line.
97 civic ex turbo
13.1@112
94civicoupe
where does this go?
why is there a vaccum type hose for cruise control, whats it's function????
Image SOLD!!!!!!
v-tecivic
where does this go?
Post by v-tecivic »
94civicoupe;99949 wrote:why is there a vaccum type hose for cruise control, whats it's function????
it is hooked up to a diaphram. basically the vacuum will pull the diaphram shut and it will in turn pull on an extra throttle cable either connected to the gas pedal or near the throttle body. it will only pull the cable a little bit. when cc is on and your cruising it has a little tension on the cable allowing you to maintain speed. when you go up a hill it will sense more engine load (or vacuum). it will then pull the cable, opening the throttle body just enough to keep your speed.
97 civic ex turbo
13.1@112
94civicoupe
where does this go?
hmm, thats really insteresting, i always thought it was computerized but, ya that makes a lot more sence, cause i mean i use my cruise control, and going up hill, ill feel that extra little pull that it has, but i always thought it was something to do with the computer modulator thats under the hood on the right by the bar that hold the hood up. lol
Image SOLD!!!!!!
where does this go?
also i had a guy on another forum say it looks like i have the wrong wires going to iat sensor he said it should be a green wire instead of the yellow one. is that true?
