gonna boost the banner mobile the civic has a d16z6 with a y8 manifold on it this is the list so far i will add more as i go i want to know what you guys think is the best company to go with for each part
Already have:
garret t3/t4 turbo 60trim
intercooler same as above
B.O.V (greddy)
turbo timer (greddy)
injectors 780cc
rods eagle
pistons srp
manifold ebay
hondata s300
3 bar map sensor
oil line kit
arp headstuds
boost controller
stuff that i need:
piping treadstone
fuel pump thinking walbro
clutch
cam zex 56300
head work good place to get this done
spark plugs ngk
wastegate dumptube
exhaust and downpipe
valve springs zex
i know i have left abunch of stuff off that need. i don't know what else to add seeing as i have never done this before i need all the advice and help i can get :help:
ok here we go
civic4life13
ok here we go
^matt talking about going down on black girlsMatt;80636 wrote:when you go down on them they kinda look like burn victims
RICE4LIFE Member #1
I'm gonna do the things I wanna do, I aint gotta thing to prove to you - WEEZER
09 Civic SI faster then half the board and its stock
ok here we go
How much power are you wanting?
civic4life13
ok here we go
i am looking for atleast 300hp to the wheelsSilverStreak;70878 wrote:How much power are you wanting?
RICE4LIFE Member #1
ok here we go
then youll probably want to add a clutch, cam, and headwork to the list :dunno:
ok here we go
injectors - Go with a 750cc Injector incase you ever want to upgrade. RC makes a set for $376 on TunerToys.comcivic4life13;70877 wrote:gonna boost the banner mobile this is the list so far i will add more as i go i want to know what you guys think is the best company to go with for each part
Already have:
wastegate not sure brand came off a nissan nx
B.O.V (greddy)
stuff that i need:
rods (eagle) - Eagles are a good choice. Like I told you earlier, they're holding 463whp on D's.
pistons (arias) - Again, good choice. One of the best pistons on earth.
manifold - Ramhorn FTW! LoveFab, Autowerks, and Full-Race are some good places to look for these.
piping - Treadstone looks to be the best kit from what I've seen. 2.5" aluminum piping with all silicone couplers and T-Bolt clamps. You can order it with a flage for your GReddy RS BOV too. $289.95
fuel pump thinking walbro - A 255lph should be good for what your wanting
hondata s300 - This is a good choice too. Look into other EMS systems to make sure the s300 is what your wanting. AEM EMS, EcTune, Neptune RTP, Crome/Crome Pro...
What I noticed your going to need...
3 Bar MAP sensor - Eveyone getting 300whp is boosting between 14-21 psi. The stock MAP sensor is only good for up to 12 psi.
Zex 59300 cam - This is the cam most D guys use. No valvetrain upgrades required.
Oil Line Kit- Stealthmode Performance FTW! $89 shipped
Exhaust and downpipe - I'm a fan of 3in. open downpipe. Look into exhausts a little more and figure out what your needs are.
Wastgate - Make sure you have the right size wastegate for the manifold you got.
ARP Headstuds - They're about $90
Spark Plugs - NGK BKR7E
Y8 Intake Manifold
Wastegate Dumptube
Boost Contorller - Manual or Electronic. Its up to you and your needs.
Clutch - I perfer Exedy
LSD - Might want one for when you go to the track.
Hope this helps.
civic4life13
ok here we go
^^^^that helps alot thanks rob
RICE4LIFE Member #1
civic4life13
ok here we go
what about valve train upgrades what do i need to get?
RICE4LIFE Member #1
ok here we go
Nothing. Stock valvetrains will hold up to 400+ horsepower. Just drop in the ZEX cam and your good to go.civic4life13;70983 wrote:what about valve train upgrades what do i need to get?
ok here we go
taken straight from hereSilverStreak;70985 wrote:Nothing. Stock valvetrains will hold up to 400+ horsepower. Just drop in the ZEX cam and your good to go.
SEVERE STREET / COMPETITION
Best performance cam available. Large increases above stock cam from off idle to the rev limiter. Excellent high RPM power. Requires Spring #912-16. 2000 to 7200 59300
