a/c cold then warm!?
DC_T
Its insanely hot outside right now and my a/c in my 97 integra has decided to act up on me. On the highway it works great, gets cold and works fine. Problem starts when I stop. If I'm just sitting at idle it quits blowing cold air. It will usually start back blowing cold air when I start moving again, but sometimes it doesn't. It kind of picks when it wants to work. Any ideas?
Maybe needs a recharge?
LowePerf
Check your cooling fan. It pulls heat from the condensor(in front of the radiator)while your stopped, when going down the road airflow alone will do the job.
-John
-John
618-463-0224
618-463-0224
xtremesq
Could be the water valve getting stuck open....at least in BMWs that can be the case!!!
I know a trick for helping your ac stay cold that we do on the S2000s..... if I can find the link again I'll give it to you.
Coming Soon ..... Rebirth of the S2000
