Need help ASAP!
JonDubya
Need help ASAP!
Post by JonDubya »
Hey guys,
So my car's not starting unless the engine is cold. And when it does start, it starts horribly and then at idle it'll rev up to 3000rpm then drop to 2500 and then rev back up to 3k (repeating). Is this my IACV? I need to get this fixed asap since it's my only car.
1997 AIGSR.
trophaeum: hows it sound to u to be in amsterdam fucked up on any drugs we can lay our hands on with legal weed for at minimum of 8hrs
Fucking eh cotton!
JesSi
Need help ASAP!
Post by JesSi »
JonDubya;33624 wrote:Hey guys,
Take it off, clean it and see if that was it.
Need help ASAP!
Post by rickles8099 »
do you have a vaccuum leak?
or have you messed with anything lately?
JonDubya
Need help ASAP!
Post by JonDubya »
WIring to the ecu was a little fucked, but i fixed it. and then a friend of mine messed it up again, and it's been downhill since then. not throwing a CEL. When I try to start the car and it won't start, the IACV makes some weird buzzing noise. not sure how to clean it out.
1997 AIGSR.
Fucking eh cotton!
Need help ASAP!
Post by andyjt »
JonDubya;33645 wrote:WIring to the ecu was a little fucked, but i fixed it. and then a friend of mine messed it up again, and it's been downhill since then. not throwing a CEL. When I try to start the car and it won't start, the IACV makes some weird buzzing noise. not sure how to clean it out.
Take it off, usually dirt and grime get stuck on the filter.
JonDubya
Need help ASAP!
Post by JonDubya »
And that's it? Any disassembly?
1997 AIGSR.
Fucking eh cotton!
thsmrtone1
Need help ASAP!
Post by thsmrtone1 »
no CEL when idleing that high? thats surprising... its gotta be some sort of vacuum leak though because the amount of air that is needed to idle that high cannot be done without quite a bit of vacuum leak...
I miss my honda ;(
Need help ASAP!
Post by andyjt »
JonDubya;33690 wrote:And that's it? Any disassembly?
you cant its pretty much sealed up. Just clean the filter out and thats about the best you can do!
ludeboy
Need help ASAP!
Post by ludeboy »
Most likely the IACV, get a new one and slap it on. Same happened to my civic.
thsmrtone1
Need help ASAP!
ludeboy;33967 wrote:Most likely the IACV, get a new one and slap it on. Same happened to my civic.
or borrow someone else's just to make sure thats the problem...
I miss my honda ;(
