Swapped Ks? anyone
No Dig
Swapped Ks? anyone
Post by No Dig »
whos running a swapped K series? Im considering doing a k20 with the 2.3 stroker kit, instead of turboing the LS thats in the car now. Anyone out there with any good info or a swapped car I can check out?
2004 neon: 639/649 on 93. 67mm/150 hit
2004 zx14
1987 Grand National
JesSi
Swapped Ks? anyone
Post by JesSi »
No Dig;30222 wrote:whos running a swapped K series? Im considering doing a k20 with the 2.3 stroker kit, instead of turboing the LS thats in the car now. Anyone out there with any good info or a swapped car I can check out?
What do you want to know? You'll need new axles, a Type-S or 98 Accord shifter, mount kit from hasport, probably a TSX DC Sports header...
Search K-Series.com and K20a.org.
lsvtecrex
Swapped Ks? anyone
Post by lsvtecrex »
Just know that the swap alones gonna cost at least 7 g's,and thats if you catch deals an do the work yourself.Add the stroker kit,hondata,and tuning and your lookin at a major investment.All motor,especially a k swap,kick ass.But you can make mo powa fo less money with the turbo ls.Just my 2 cents.
lil' man
Swapped Ks? anyone
Post by lil' man »
keep us posted if you do go k series!!!:thumbsup:
destructn
Swapped Ks? anyone
Post by destructn »
lsvtecrex;30301 wrote:Just know that the swap alones gonna cost at least 7 g's,and thats if you catch deals an do the work yourself.Add the stroker kit,hondata,and tuning and your lookin at a major investment.All motor,especially a k swap,kick ass.But you can make mo powa fo less money with the turbo ls.Just my 2 cents.
+1..
The K20a that we put in Jesse's car ran us almost up to 9k. the motor was 5.5k alone at the time we did this, 2+ years ago... thats not including mounts, (which we had the first hasport mounts made for this swap and broke them 3x)axles, shifter + cables, harness, rcrew header, etc... I wouldn't even think of doing the stroker kit until you have a solid kswap.. a good K20a will lay down some crazy power but at a high price.. for the money put a turbo on your ls and go from there...
I also recommend that like guy said above, check out k20a.org
zrs6v4
Swapped Ks? anyone
Post by zrs6v4 »
I was going to do the same thing in my crx, and it has a b18 in it already. after mounts, shifter box, axles, header, hood (K's are taller) it was quite pricey and I decided to just turbo what i have. If money wasnt a factor I would do the swap for sure.
