pass emissions?
DC_T
pass emissions?
How do you guys pass emissions? I have a turbo 97 Integra running a chipped p28 and i have to get it checked this year, so i have to figure something out.
JonDubya
pass emissions?
Swap in stock ecu for the test...they'll just plug it in to the OBDII scanner and if all is well you pass! Additionally you can pay the waiver fee, but I think that it has been jacked way up...like $250-500. I just did this 2days ago, but I'm running a stock ecu anyways.
1997 AIGSR.
trophaeum: hows it sound to u to be in amsterdam fucked up on any drugs we can lay our hands on with legal weed for at minimum of 8hrs
Fucking eh cotton!
Fucking eh cotton!
DC_T
pass emissions?
I would, but i don't know if my car would run so good w/ a stock ecu. i'm running rc550 injectors, plus w/ all the turbo stuff i don't know how safe it would be to drive up there w/ no kind of tune. Any other suggestions?JonDubya;16312 wrote:Swap in stock ecu for the test...they'll just plug it in to the OBDII scanner and if all is well you pass! Additionally you can pay the waiver fee, but I think that it has been jacked way up...like $250-500. I just did this 2days ago, but I'm running a stock ecu anyways.
JonDubya
pass emissions?
You can try my ecu and see how it runs? If so I'll let you borrow it for the test.
1997 AIGSR.
Fucking eh cotton!
Fucking eh cotton!
DC_T
pass emissions?
thanks...i just don't think its a good idea to run my setup on a stock ecu. I might end up having to take all my turbo stuff off for the emissions, which would suck ballz...stupid emissions:piss2:JonDubya;16318 wrote:You can try my ecu and see how it runs? If so I'll let you borrow it for the test.
pass emissions?
HAve any good friends outside of st. louis? change your address to theirs and bam no emissions.
pass emissions?
they only read the ECU, so as long as it says everything is fine, there shouldn't be a problem...right?
DC_T
pass emissions?
i have a p28 (obd1) though in a 97 integra (which is supposed to be obd2). i don't think they plug into obd1 ecu, and when they look for an obd2 ecu to plug into and see that its not there, i guess i fail.Spork;16337 wrote:they only read the ECU, so as long as it says everything is fine, there shouldn't be a problem...right?
pass emissions?
disconnect the chargepiping going to your throttle body, put in stock injectors, and then put in a stock ecu. youll be running n/a on a stock ecu and not hurting the car at all. once you get done with the emmission testing, put the aftermarket injectors and ecu back in and the reconnect the chargepiping. bam.. your back to f/i
pass emissions?
when we were trained to do emissions testing, we had to use a five gas analyzer, which reads all the gasses coming out of your tailpipe. it gives yo a printout of all your emissions readings, and if it is not within spec, you FAIL! i live in lincoln county(HAHA) so ive never witnessed it, but i think that there is more to it than just reading the ecu. im not sure though, so dont jump all over me.
