opk guys i bought a 92 ex civic with a d15b7 motor blew and this motor was there so they put it in
im getting a d16y8 from andyjt what all do iu need to make it work?
let me know im its gonna be a bit b4 it goes into the car..
block and crank going to machine shop.
gonna install block gaurd. and forge inturnals for boost.
what ecu do i need?
and do i need to mess with the wiring?
the car already has the y8 manifold on it
thanx:drinkup1:
help me
help me
if it was a y8 before, you should be pretty much good to go, just make sure you are running the right ecu (i don't know which one that is- im not a d-series guy) it should just be plug and play for you...91turbo;10426 wrote:opk guys i bought a 92 ex civic with a d15b7 motor blew and this motor was there so they put it in
what ecu do i need?
thanx:drinkup1:
help me
d16y8 should bolt right up you my have to change plugs and lengthen wires. you should get a p28 ecu, i wouldnt use a block guard i would post the block...91turbo;10426 wrote:opk guys i bought a 92 ex civic with a d15b7 motor blew and this motor was there so they put it in
what ecu do i need?
thanx:drinkup1:
edit: you can actually just plug everything in and run your stock ecu it will run, but for turbo and chipping i would use a p28...
help me
block posting:91turbo;10435 wrote:ok i belive it had a d16z6? was vtec had turbo at one time
you say no block gaurd?
whats post the block?
http://www.homemadeturbo.com/tech_proje ... index.html
if its wired for vtec the motor should be plug and play like spork said...
help me
plugs should all be the same minus the air temp sensor, the y8 has it on the air intake and the z6/b7 have it on the intake manifold so you will have to address that...91turbo;10439 wrote:kool lets hope so.. but y8 out of a 00 that obd2 and car is a obd1
