wiring harness guru's please step in
deetz
k got a question, with my 90 integra can i use a stock harness on a b16? or do i need a b16 harness, odb0 of course, i beleive i have a problem inside of it
~chris~
-scca setup 99 grand am gt
-85 cj7
-85 cj7
mike
its always a good idea to use the harness that came with/was made for that engine
Signature removed please contact any moderator.
you can use the stock obd0 harness like we did...
deetz
ive replaced everything but the harness, and it was a coincedence i started having problems after i replaced mty head, im thinking i forgot to ground it somewhere or a wires broken off somewhere, im just gonna have chris n2hifi prolly redo me one, im just wondering if i need to remove mine or can i go to the junk yard and remove a whole harness from a car.
~chris~
-85 cj7
-85 cj7
If everything is obd0 on it I would just stay obd0 instead of finding a obd1 dist, and obd1 ecu and what not. We run obd0 on our 91 B16a integra and it runs perfectly fine.
deetz
oh i am running it, im only gonna convert if i go turbo, ive done made that decision
~chris~
-85 cj7
-85 cj7
dumb question, but is that ground strap that mounts to the thermostat housing hooked up?
deetz
would that cause it not to have spark??? i havent been able to find a ground strap anywhere in that area
~chris~
-85 cj7
-85 cj7
the car would not run period, its the ground for the engine harness. it shoud come right off the t-stat housing 10mm bolt with a wire or wires going into the harness...deetz;8062 wrote:would that cause it not to have spark??? i havent been able to find a ground strap anywhere in that area
deetz
yea there isnt one, i wonder if it broke off or something
~chris~
-85 cj7
-85 cj7
