wiring harness guru's please step in
deetz
Post by deetz »
k got a question, with my 90 integra can i use a stock harness on a b16? or do i need a b16 harness, odb0 of course, i beleive i have a problem inside of it
~chris~
-scca setup 99 grand am gt
-85 cj7
mike
Post by mike »
its always a good idea to use the harness that came with/was made for that engine
Post by 90CivicEx »
you can use the stock obd0 harness like we did...
deetz
Post by deetz »
ive replaced everything but the harness, and it was a coincedence i started having problems after i replaced mty head, im thinking i forgot to ground it somewhere or a wires broken off somewhere, im just gonna have chris n2hifi prolly redo me one, im just wondering if i need to remove mine or can i go to the junk yard and remove a whole harness from a car.
~chris~
-85 cj7
Post by 90CivicEx »
If everything is obd0 on it I would just stay obd0 instead of finding a obd1 dist, and obd1 ecu and what not. We run obd0 on our 91 B16a integra and it runs perfectly fine.
deetz
Post by deetz »
oh i am running it, im only gonna convert if i go turbo, ive done made that decision
~chris~
-85 cj7
Post by stolle »
dumb question, but is that ground strap that mounts to the thermostat housing hooked up?
Team NOCO Crew Member #2
deetz
Post by deetz »
would that cause it not to have spark??? i havent been able to find a ground strap anywhere in that area
~chris~
-85 cj7
Post by stolle »
deetz;8062 wrote:would that cause it not to have spark??? i havent been able to find a ground strap anywhere in that area
the car would not run period, its the ground for the engine harness. it shoud come right off the t-stat housing 10mm bolt with a wire or wires going into the harness...
deetz
Post by deetz »
yea there isnt one, i wonder if it broke off or something
~chris~
-85 cj7
