i have a z6 ob1 p28
for some reason it still has the a6 obd0 dizzy on the car :gay:
i just picked up a z6 dizzy, now do i need to buy the plug and play harness for 30bucks or is this an easy wiring job?
the car idles a little rough and i dont think im getting the MPG i think should be... thus the reason i want to put the right dizzy on the engine.
any help/info would be great
dizzy help
mike
dizzy help
Signature removed please contact any moderator.
mike
dizzy help
tis easy wireing, if you have the manual for 0d0 and obd1. which would be a chiltons and if ya don't have one don't fret cause you can borrow mine.
dizzy help
i doubt that its an a6 dizzy, do all the bolt holes line up to the head? if they dont its most likely a d15b7 obd1 dizzy, if they do you already have a z6 dizzy. the obd1 and obd0 dizzys are different internally and are not compatible (something with the crank angle sensor i believe) you cant use an obd0 dizzy with a obd1 ecu. if you have a z6 dizzy you want to use it is as simple as depinning the plugs and installing obd0 plugs i have a z6 dizzy thats got ond0 plugs on it i dont remember off hand what wire goes where but i can check and let you know...
dizzy help
check out this link i used it to make my own conversion harness and rewire my distributer...
http://www.pgmfi.org/twiki/bin/view/Lib ... sOBD0-OBD1
mike
dizzy help
yes it was an a6 dizzy...the shop*cough*adrenaline*cough* that did the swap cut off one dizzy arms so that it only used two bolts.stolle;4266 wrote:i doubt that its an a6 dizzy, do all the bolt holes line up to the head? if they dont its most likely a d15b7 obd1 dizzy, if they do you already have a z6 dizzy. the obd1 and obd0 dizzys are different internally and are not compatible (something with the crank angle sensor i believe) you cant use an obd0 dizzy with a obd1 ecu. if you have a z6 dizzy you want to use it is as simple as depinning the plugs and installing obd0 plugs i have a z6 dizzy thats got ond0 plugs on it i dont remember off hand what wire goes where but i can check and let you know...
got it on and the car runs A LOT better!
dizzy help
It looked like it had an OBD0 dizzy on there if I'm not mistaken. We put on a OBD1-OBD0 conversion harness w/ the OBD1 dizzy and it seemed better, but not 100%.stolle;4266 wrote:i doubt that its an a6 dizzy, do all the bolt holes line up to the head? if they dont its most likely a d15b7 obd1 dizzy, if they do you already have a z6 dizzy. the obd1 and obd0 dizzys are different internally and are not compatible (something with the crank angle sensor i believe) you cant use an obd0 dizzy with a obd1 ecu. if you have a z6 dizzy you want to use it is as simple as depinning the plugs and installing obd0 plugs i have a z6 dizzy thats got ond0 plugs on it i dont remember off hand what wire goes where but i can check and let you know...
Ninja Edit: Mike beat me to it.
mike
dizzy help
i stopped and tapped the timing forward a bit.. its runs fantastic now... for a dseries anyways:fag:SilverStreak02;4304 wrote:It looked like it had an OBD0 dizzy on there if I'm not mistaken. We put on a OBD1-OBD0 conversion harness w/ the OBD1 dizzy and it seemed better, but not 100%.
dizzy help
Thats good to hear then. I'm glad its running properly now.mike;4313 wrote:i stopped and tapped the timing forward a bit.. its runs fantastic now... for a dseries anyways:fag:
