My hatch is holding water and I have an idea how its getting in, but Im not sure. I havent had a chance to actually get back there and see. My preliminary guess is that the redneck I bought it from somehow damaged the hatch. Because when I raise it up past a certain point, it makes a weird pinging sound and makes the same noise when I put it down. Theres a (looks like) sheet metal replica of the stock wing tack welded on...
I dont want to replace the whole hatch if I dont have to. Any ideas on how to go about fixing this?
Leaking (ef)hatch >:(
Q10
I do! I didnt know there was a drain...
gcef89
yea my hatch use to hold water cause my drain was filled replaced the drain lines and now no leakes although my gf crx is leaking through the hatch and i have no clue were its coming from?
Q10
are those drain lines under the headliner?gcef89;263947 wrote:yea my hatch use to hold water cause my drain was filled replaced the drain lines and now no leakes although my gf crx is leaking through the hatch and i have no clue were its coming from?
getteg
Most likey they run throught the A pillars and the C pillars. Drop the headliner and you will see them coming off the corners of the sunroof.
Save a mouse....eat a pussy!
