Removing Tint
92_luder
Removing Tint
does anyone kno how to remove tint from the rear window......i dont wanna ruin my defrost matrix
twkdcd595
Removing Tint
all purpose 409 cleaner and a plastic black trash bag I heard... plus some patience.
CmeltoN
Removing Tint
if you wanna go cheap you can mix vinegar and water equal parts and it eats the adhesive right off....
MaSSaCrE
Removing Tint
I also have tons of tint remover liquids,sprays,tools, whatever up at my work (Crest Industries)
95_gsrfodo
Removing Tint
black trash bag on the rear window leave it in the heat "sunlight"
lay something on the inside of the car so u dont get it messy
windex will work soak the window... try and peal it a little in the corner and spary it there let it set..
go back to it a while later after sitting in the heat..
try and peal if it starts coming keep sparying as u peal it will help eat the glue.. u need the windex and heat for it to work
4 Doors = More Whores
92_luder
colten
Removing Tint
I'd get the tint residue hot with a heat gun or by parking the car outside on a hot summer day. Then peal the tint off. Then I'd carefully use a razor blade to scrape off the residue between defrost strips and use WD40 to remove the residue on the strips themselves. It will leave a greasy residue but it'll come right off.
Thats what I've done several times in the past and the rear defrost has always worked.
92_luder
Removing Tint
ok...heat gun....wd40.....razor....adn a cover for my backseat so i dont make a mess
master b
Removing Tint
I 2nd the windex and trashbag. Just soak the tint on rear window with windex cover the inside of the window with black trashbag. Park in the sun for 20 or 30 mins or untill the window is hot. And the tint peals right off. Dont use a razor youll mess up the rear defroster. And DO NOT use a heat gun on your window. lol you wont have one when your done92_luder;259876 wrote:ok...heat gun....wd40.....razor....adn a cover for my backseat so i dont make a mess
