? for the pro's
getteg
? for the pro's
Post by getteg »
I am wondering how to take the floor pans apart in a DC teg. I have the back half of a DC and I was thinking about keeping the floor pans just in case someone ever hits me and I need them.
Is there an easy way to remove them or no. I see there is like a glue or sealer but whats under thet? Spot welds?
Any info would be great.
Thanks
Brian
Save a mouse....eat a pussy!
? for the pro's
Post by andyjt »
scrap it. The parts arent that expensive new.
? for the pro's
Post by 5thgen »
It shows for $720 from acura with each sill metal ($90 each by themselves) for the floor under the seats. The rear floor is listed at right under $600.
Story Worm
? for the pro's
Post by Story Worm »
Yea there are spot weld. Never seen how many but thats what is under there. The seam sealer is there just to seal it up.
? for the pro's
Post by RyanA »
Well, if you want to do it the easy way and leave enough for a body shop if you ever need them, just use a sawzall and cut up higher so you have extra (cut across the quarters above rockers, etc) meat for them to splice wherever they want.
getteg
? for the pro's
Post by getteg »
See the thing is I am deff keeping the quarters for a project DC that I plan on getting, as the ones on the back half I have are 100% rust free. Im sure whatever project I get which will be a 94 or 95 will prob have rust.
How do I remove the sealer? Will it scrape off easily or do I need to heat it up or is there another way?
Thanks again for the info.
? for the pro's
Post by RyanA »
Heat gun and a putty knife takes it off. If you want to take things apart at the seams, get a spot weld drill bit (looks like tiny hole saw) and drill all the welds. You can then carefully pry the pieces apart.
