First gently pry up the outer corner with a regular screw driver, or something similar, plastic would be prefferd...
Next, in a downward motion, pull the top of the molding toward you, start on the outer most corner, theres no need for muscle so be gentle...
This is how it should look, keep going to the end...
At this point the molding is ready to be lifted off... gently wiggle from right to left and in an upward fashon...
It is now off... :TU:
