Toyotas
SupraRacer
Toyotas
i have tons and tons of resources concerning toyota performance, and toyota engines(specs, etc) so feel free to request something if need be.
~Ryan
90' Singl'd 1j Supra
Too old
Too heavy
Too few cyl's
Too much Lag
"Real Cars dont make power at the front wheels, They lift them" - Tosto Racing
Too old
Too heavy
Too few cyl's
Too much Lag
SupraRacer
Toyotas
PAY ME to do it.....budget_crx;3093 wrote:I want to put a 2JZ in an 86 pickup. tell me how
~Ryan
Too old
Too heavy
Too few cyl's
Too much Lag
Too old
Too heavy
Too few cyl's
Too much Lag
SupraRacer
Toyotas
No. the 3s-fe has narrow angle cams (F in the engine code) usally dont make as much power as wide angle (G in the engine code) so the 3s-gte has larger cams and stronger springs, although a 3sgte head will bolt up to a 3sfe motor the 3sfe motor has weaker internals and everything in the gte is built stronger. so you may be able to swap out parts but you cant just swap out say one valve and spring and not replace all the rest without problems. And in the US they only had the 3s-fe in the 1st gen stage(86-89), meaning only the first gen 3s-gte would bolt up.
~Ryan
Too old
Too heavy
Too few cyl's
Too much Lag
Too old
Too heavy
Too few cyl's
Too much Lag
