Rebuilt 305 Runs then dies
MaSSaCrE
Post by MaSSaCrE »
So I need some help. Rebuilt\Built 305 fuel injected starts right up but dies within second???? Replaced Injectors,fuel pump,fuel filter,fuel lines,new gas,bla bla bla. I know this is not the site to be asking but im asking all over for some help on this id love to know whats up and im not the smartest with this shit.
Car was sitting for quite a bit of time if that helps anyone.
Post by RyanA »
Oil pressure switch not hooked up or broken? The ECU only primes the fuel pump so the vehicle can start. After that, the oil pressure switch keeps the pump running. I'd give you more explanations but I'm guessing this is the problem....
MaSSaCrE
Post by MaSSaCrE »
do you know of any way to figuring out if thats it without changing it out
MaSSaCrE;189401 wrote:do you know of any way to figuring out if thats it without changing it out
first I would check to see if its hooked up, then test resistance on the line from the sensor to the ECU. If thats all good, I would the the voltage specs of the sensor itself and test it.
Post by andyjt »
The oil pressure switch keeps the fuel pump circuit grounded throught the Oil pressure switch. You could potentially just jump the switch. Look at the wiring diagram and figure it out.
MaSSaCrE
Post by MaSSaCrE »
Alright thanks. All else fails ill prob just 350 swap and save myself from spending a few hundred in injectors,new sensors,distributor,and all that. Ill try the first few most expected things then if nothing works, swap.
Post by andyjt »
MaSSaCrE;189414 wrote:Alright thanks. All else fails ill prob just 350 swap and save myself from spending a few hundred in injectors,new sensors,distributor,and all that. Ill try the first few most expected things then if nothing works, swap.
And if all else fails swap it out? You have the WORST shotgun apporach of a mechanic. Good luck tossing on parts.
-Andrew
MaSSaCrE
Post by MaSSaCrE »
So whoever feels like helping knows the car stopped starting on its own. If i constantly poor gas or fluids in the tb it will remain running but as soon as i stop feeding it to the car it dies. I can rev it up while someone poors gas in and sounds like it runs good no problems there.
MaSSaCrE
Post by MaSSaCrE »
andyjt;189415 wrote:And if all else fails swap it out? You have the WORST shotgun apporach of a mechanic. Good luck tossing on parts.
-Andrew
well either way along the lines im swapping a 350 in because 305's just dont have any power to me but i guess that my personal opinion. So why spend that amount of money on parts to get it running when im 350 swapping either way it would just be nice to be driving it for a little and save some money up for a nicer motor
LowePerf
Post by LowePerf »
What kind of car is it? Does it have a Pass-Key system?
618-463-0224
