UPDATED PIX of my non honda zr2 blazer
95_gsrfodo
Post by 95_gsrfodo »
ok well this was on of redline old cars he had for maybe a month and i wanted it more then he did so i traded my gsr swapped 4 door teg for it
after a little work and cleanup here it is now..
in some of the pix the truck looks almost black but it is blue!
i know i need someone to get some better shots of the truck i dont do it justice..
‎4 Doors = More Whores
xslickwhitetegx
Post by xslickwhitetegx »
all it needs is wrench on the front between the fogs! is that a skid plate I see?
UKDM Whore
95_gsrfodo
xslickwhitetegx;267091 wrote:all it needs is wrench on the front between the fogs! is that a skid plate I see?
ment to say a winch? ya truck has full skid plates under the truck...
fry
Post by fry »
cool...a chevy...blazer. where are the truck nuts and chevy emblem exhaust tips?
Redline
Post by Redline »
james you need to stop being lazy and put the lift on.
More power coming soon
95_gsrfodo
Redline;267096 wrote:james you need to stop being lazy and put the lift on.
i tried today i got the front control arms are on....
the rear shackles and springs ned t wait i have to order new spring eye bushings.. the bolts are seized... after all that soaking them in pb blaster it didnt help!!
95_gsrfodo
you seen it clean now see it dirty
modthesol
Post by modthesol »
nice pickup. get it? no, ok. i wish those didnt weigh so much.
edit: also ditch the back wheel or get the same tire you are runnning and lose the cover.
kra95civic
Post by kra95civic »
95_gsrfodo;267098 wrote:i tried today i got the front control arms are on....
have you tried heat? heat up the bolt hit it with a hammer and keep spraying pb blaster. that shit will work through eventually.
Post by stolle »
solid axle swap, and the thing would be bitch!
Team NOCO Crew Member #2
