after a little work and cleanup here it is now..
in some of the pix the truck looks almost black but it is blue!
i know i need someone to get some better shots of the truck i dont do it justice..
ment to say a winch? ya truck has full skid plates under the truck...xslickwhitetegx;267091 wrote:all it needs is wrench on the front between the fogs! is that a skid plate I see?
i tried today i got the front control arms are on....Redline;267096 wrote:james you need to stop being lazy and put the lift on.
have you tried heat? heat up the bolt hit it with a hammer and keep spraying pb blaster. that shit will work through eventually.95_gsrfodo;267098 wrote:i tried today i got the front control arms are on....
the rear shackles and springs ned t wait i have to order new spring eye bushings.. the bolts are seized... after all that soaking them in pb blaster it didnt help!!
