94 accord speedo and odo not working still...
zrs6v4
Post by zrs6v4 »
94' accord 5speed lx no abs-
the speedometer quit working, it doesnt read mileage or speed but rather bounces between 15 and 20mph.
here is what ive done so far
- smacked the dash and kicked the bumper
- changed the VSS which resulted in it working at random times
- cruise control is not working
- i bought a new cluster to check it but i havent done it yet
any ideas? i am hoping i didnt get a bad new vss from autozone
slowagon
Post by slowagon »
most likely your vss. my 91 was doing the same thing-speedo/odo not working. snagged a vss from the junkyard and threw it in and no more problems.
As for autozone, I wouldn't buy fuses from that place. Everything electrical I've ever bought from them has failed...double check your vss....
Clayton
Post by Clayton »
check the plug going into the vss i bet the middle pin is coroded
nomoneyleft
Post by nomoneyleft »
what he said. i sounds like a bad connection. pull the cluster and make sure nothing is loose
:PDT_pop:
zrs6v4
Post by zrs6v4 »
still working on it, thanks guys
