But i just recently got a 1990 integra with a b16a1 jdm swap. The car runs and drives awesome BUT here are my issues.
there is no vtec And the fuel cuts a 6500 rpm. So i am thinking the car has the wrong ecu. I cannot find any numbers on the ecu.
Everything that i am reading is saying the i need to buy a pr3 ecu which is pricey from where i have looked. Or i can obd1 boomslang and get a obd1 pr3 with a base map and the car will run better.
Bare with me guys i realize this is a noob question but as i have said this whole honda thing is new to me. I grew up in a garage building small blocks and then i got into miatas. So all the tuning i know is with a wideband and jets or megasquirt.
well i got this car for a fun daily driver while i swap an engine into the miata. So if you guys dont mind throw me a few bones here and help a noob out. Also if it is a simple fix can you guys send me in the right direction to getting this car running like it should. i dont want it to be a race car. But i would like vtec and the rev limiter to work correctly.
thanks guys. Also ill throw up a few pictures of my miata just because pictures make threads better.
here is the motor going in it
