Help a New guy out.
turbotyla
Help a New guy out.
Post by turbotyla »
Alright guys i am new to hondas/acuras in general i am a miata guy.
But i just recently got a 1990 integra with a b16a1 jdm swap. The car runs and drives awesome BUT here are my issues.
there is no vtec And the fuel cuts a 6500 rpm. So i am thinking the car has the wrong ecu. I cannot find any numbers on the ecu.
Everything that i am reading is saying the i need to buy a pr3 ecu which is pricey from where i have looked. Or i can obd1 boomslang and get a obd1 pr3 with a base map and the car will run better.
Bare with me guys i realize this is a noob question but as i have said this whole honda thing is new to me. I grew up in a garage building small blocks and then i got into miatas. So all the tuning i know is with a wideband and jets or megasquirt.
well i got this car for a fun daily driver while i swap an engine into the miata. So if you guys dont mind throw me a few bones here and help a noob out. Also if it is a simple fix can you guys send me in the right direction to getting this car running like it should. i dont want it to be a race car. But i would like vtec and the rev limiter to work correctly.
thanks guys. Also ill throw up a few pictures of my miata just because pictures make threads better.
here is the motor going in it :)
skittle_107
Help a New guy out.
Post by skittle_107 »
In for thread title change!
Level 7 Motorsports | Zen Motors
Help a New guy out.
Welcome. The B16A1 swap is not JDM, it's from the European market.
If there is no longer a label on the ECU case, take the top cover off and look for the label on connector. Use this picture as a reference. The label is in the top left corner on the green connector.
Mazkid
Help a New guy out.
Post by Mazkid »
Kl-ze?
1994 Protege BP-Turbo.....1994 Miata w/JRSC.....2003 Protege5 V6 swap.....2003 Protege5 daily.....1988 323 GT turbo.....2003.5 Protege5 fixer-upper.....2004 RX-8
turbotyla
Help a New guy out.
Post by turbotyla »
Well thats nice to know. A lot of information. Ill get back with what ecu i have. And the mktor runs awesome so it not being jdm does not bother me at all.
And mazkid. I kmow you from clubroadster. But i was going with klze but decided for tge de. I got a good deal on the engine plus im going to boost it soon after tha swap. ;) shooting for 300whp and 2300 lbs. Thats relaible. Wish me luck haha
