twkdcd595;212214 wrote:Great shit rick!!! Nice work there broseph, budget build the crx resurrection!!!
What turbo you running there... adapter plate on a hf with a dsm terbooo?
Very nice!!! How much does the window welded mounts increase vibration? Which grade stuff did you use?
rhb5 turbo. i wouldnt go dsm turbo due to lack of reliability
window weld stuff doesnt add much to vibration, or at least shouldnt. its not acutal 3m window weld, just some stuff that i had laying around. the main goal wasnt really to decrease engine movement per harder mounts, intention was to fix the tears in the mounts by filling the holes.
gsrauto98;212215 wrote:finally lol, good to see you give the crx some attention. So Is that just a stock motor??????????????????????? i have a feeling it is not
yes its a stock motor. stock pistions, stock rods, original honda headgasket, stock head, stock cam, stock cam gear, stock water pump, stock oil pump, stock flywheel..... all engine internals are stock.
