94+ integra rear main seal install???
zrs6v4
I am installing a new rear main seal on my 99 Integra LS and I am using a felpro seal.. Anyway it came with 3 wrong gaskets as well as the right size seal. My question was what do I use for the gasket on the outside edge of the piece that bolts onto the engine? Im guessing no RTV?
andyjt
Hondabond. If your talking about the rear plate where the rear main seal attches into.zrs6v4;203683 wrote:I am installing a new rear main seal on my 99 Integra LS and I am using a felpro seal.. Anyway it came with 3 wrong gaskets as well as the right size seal. My question was what do I use for the gasket on the outside edge of the piece that bolts onto the engine? Im guessing no RTV?
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
zrs6v4
Yup, so thats what they used there... thanksandyjt;203685 wrote:Hondabond. If your talking about the rear plate where the rear main seal attches into.
I am going to pick up an Acura/Honda seal as well, do you by chance know of any other Honda cars that use the same seal so I can get it from Honda instead of driving 30 mins to Acura?
andyjt
zrs6v4;203689 wrote:Yup, so thats what they used there... thanks
99-00 civic si 94-97 Del Sol DOHC VTEC
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
zrs6v4
andyjt;203690 wrote:99-00 civic si 94-97 Del Sol DOHC VTEC
Thanks a lot, a very big help...
zrs6v4
Its also pretty awesome you have to take the oil pan off to get to the seal bolts and to take the oil pan off you have to take the downpipe off.. gotta love it...
andyjt
You can just loosen the oil pan bolts and sliper the back plate off and then install the mail seal last.zrs6v4;203692 wrote:Its also pretty awesome you have to take the oil pan off to get to the seal bolts and to take the oil pan off you have to take the downpipe off.. gotta love it...
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
u got a fel pro seal but want to buy oem acura? wow! buting the same part twice ftw!
