Im having acouple problems as you read ....
1.rpms go up and down when in park after starting up
2. I smell a burning smell after driving for awhile
3. when going from park to drive and all other gerars the car chages hard
:PDT_Armataz_01_05:
Can u guys help me out
EDIT: o yeah and i need a driverside(left) fender in any one can help out with that too.
problems with my 89 accord coupe
nomocars23
NO MNKY BIZ!!!
[ ] Drop [X] Tint [X] M3 spoiler [X] Brighter head lights [X] Blkd out tails [ ] Fogs [?] Rims [X] Exhaust
check me out: nomocars23 @ Cardomain
Sounds like you have the normal idle surge on hondas its the IAC valve or something like that.
soundqjr is correct. Check the IAC valve and clean it out and make sure the piece on the inside isn't rattling around. If it is, just take it apart and screw the piece back in. Its a real easy fix.
nomocars23
Ok So What About The Burning Smell Is It Oil Or Gas ... Or Transmision Fluid Burnin
NO MNKY BIZ!!!
TurboFreak
a burning smell isnt very specific if gas burns it catches on fire so you can rule that one out. does your car smoke? is there any wetspots around the motor if so where at?
Nik
Turbulent Motorsports
I have more torque than GOD!
nomocars23
i have seen smoke like twice, it comes from somewhere towards to the firewall ... yea i know gas was out just put that up there ... i havent seen any wetspots in the engine bay ... and for a couple days i put cardboard under my car and it did show any signs of dripage.
NO MNKY BIZ!!!
freakchris03
clndwhr
freakchris03;59931 wrote:transmission?
That's the most likely problem.
"Do you have an extension cord for the soldering iron?" -Me
"Uhhh.....I have a generator." -Andy
"Okay...." -Me
"Okay...." -Me
nomocars23
thats not good ... thats not good at all.
NO MNKY BIZ!!!
