Well... right now Im out of cash, and was thinking when I get more... should I turbo the d series? Or just save up for the b series my buddy has but could be possibly gone within the next month?
I figured... d series parts are easier to come by rather than a jdm b18c and then if I blow the motor I could pick whatever I want up from the local junkyard rather than having to order it offline.
I looked around on d-series.org and homemadeturbo.com and i was curious...
what mods are there for it to give it a little pep? its a b7 btw.
b series or d series?
Turbo the D-series cause if it pops you can find one anywhere
You already know my opinion on this :biggrin: D FTMFW!
b18b-t
b7's are so weak tho. If it was a z6 or y8/7 then that would be different. Rods are very weak on the b7
Silver Knight
then upgrade the rods. :doh:b18b-t;27149 wrote:b7's are so weak tho. If it was a z6 or y8/7 then that would be different. Rods are very weak on the b7
DC5
Its the same rods...Just the pistons are differentb18b-t;27149 wrote:b7's are so weak tho. If it was a z6 or y8/7 then that would be different. Rods are very weak on the b7
Stolle has been doing fine with his turbo B7 for more then a year now.b18b-t;27149 wrote:b7's are so weak tho. If it was a z6 or y8/7 then that would be different. Rods are very weak on the b7
b18b-t
d16 rods have different sized big ends, and different lengths.. (134 vs 136, IIRC?) if you want a stout 1.5 liter bottom end, find a JDM D15B crank or bottom end, and then you can use the D16 rods..
edit: back when i was inquiring about the b7 internals, stronger rods were like 770+shipping.. I just found some for 385+shipping so you could go that direction if you wanted to.
slos13drftr
so i can do teh mini mi swap and turbo that... hmm...
z6 head and a 14b/t25 turbo... how many hp you think i could possibly gain with me upgrading the injectors?
I'd say 160, maybe more or less.slos13drftr;27163 wrote:so i can do teh mini mi swap and turbo that... hmm...
