safety inspection??
irevto9k
safety inspection??
does anyone happen to work in that field? My back tires are a lil messed up and im pretty sure they will fail me so can anyone hook it up wit the inspection will still gladly pay
F>B+K ALL DAY :respect:
irevto9k
safety inspection??
hey not illegal just blew my cash on my alignments and camber issues otherwise would have bought new tires for the back like they are fine and still have tread but craptacular wear pattern
99PreludeSh
Sleepy Civic DX
safety inspection??
a tire will only fail if it is seperated or if belts or cords are showing......Are they that bad?
2009 Black Mugen Fit- Slow
safety inspection??
i can do them. but i just started a new job, so i really dont wan to be doin favors just yet.
irevto9k
safety inspection??
no not even close to like threads and crap broken deff would not drive on that but when i bought them the alignment and toe was messed up so it messed up my back tires...such as wierd tread wear that safety people prolly wont like
safety inspection??
technically, in the book it only states if there are cords showing. every shop is different. the book is kinda broad. and technically, if it fails for two rear tires, you can swap them to the front and pass. they are only allowed to reinspect what they failed, nothing else.Sleepy Civic DX;25661 wrote:a tire will only fail if it is seperated or if belts or cords are showing......Are they that bad?
dclduke
safety inspection??
It also states that if the tires are down to the secondary tread at three equal points(triangle) around the tire it fails. But like bildo16 stated, you can just swap them because they are only supposed to reinspect what they failed.bildo16;25727 wrote:technically, in the book it only states if there are cords showing. every shop is different. the book is kinda broad. and technically, if it fails for two rear tires, you can swap them to the front and pass. they are only allowed to reinspect what they failed, nothing else.
I tended to be a dick when it came to "safeties," but I also had to deal with dickhead customers so I was okay with it.
safety inspection??
ive also heard of the secondary tread thing being thrown back at inspectors, truthfully, its better to be lenient than strict, cause if you piss of the wrong person and they call troop c, you are fucked royaly. although it says you cant reinspect something that fails, i would still not pass the car if they swapped tires, if they didnt like it, id tell them to leave and go somewhere else, unless i know you, then i just deliver your approval notice and sticker, im tight like that.dclduke;25792 wrote:It also states that if the tires are down to the secondary tread at three equal points(triangle) around the tire it fails. But like bildo16 stated, you can just swap them because they are only supposed to reinspect what they failed.
