StlHondas Boosted Crew
Post by rickles8099 »
Rules for this thread:
1. Post up here if you are boosted.
2. If you are not boosted, or will be boosted soon, don't post.
3. In your post, list what kind of turbo you have, bov, intercooler, etc on your setup. Post pictures of your setup too if you would like.
4. If you have already posted your setup, and then changed something on it, instead of making a new post, edit your original post. This way we can keep the thread short, sweet, and simple.
5. No comments. If you want to comment/have a question about someones setup, post it in the thread called StlHondas Boosted Crew Comments.
6. Hondas only. Don't post about your dsm, srt-4, or whatever else that is boosted. Since this is a honda forum, lets keep this thread about hondas.
7. No post whoring or thread jacking (Mike :) )
Post by budget_crx »
'89 CRX Si
1.6L JDM DOHC ZC
OBD0 PM6 ECU, Tuned with Turboedit
Garrett T25 Turbocharger
8psi of boost
Civic STD manifold
JohnnyRacecar FMIC
HKS SSQV BOV
DSM 450cc injectors
Stolle Tuning downpipe
JDM ZC L3 Transmission
Integra equal length half shafts
ACT TOB
Centerforce Dual Friction Clutch
99BlackHatch
Post by 99BlackHatch »
'99 Civic Hatchback
JDM SiR B16 DOHC VTEC
Turbonetics T3/T4 60 trim Turbocharger
7.5 psi of boost
SSAutochrome Equal Length manifold
Ebay Brand Intercooler
TurboXs BOV
Tial 38mm Wastegate w/ dump tube
Rc 550cc injectors
Apex'i Power Fc Stand Alone ECU (B16B)
(Unhappy with the current setup, changing soon)
SquadronOne.net
modthesol
Post by modthesol »
95 Del Sol
JDM B18c W/ itr tranny
Garrett T3 70 trim
Greddy type rs BOV
" " boost and oil gauge
" " turbo timer
" " exhaust evo II
B&M fuel pressure gauge
Edelbrock JG intake manifold
Walbro fuel pump
clutchmaster stage 4 clutch
" " aluminum flywheel
550cc RC racing injectors
Mini-Me custom manifold
Custom 3" downpipe
Tial 38mm wastegate
FBR boost controler
PWR intercooler 22x8x3
granturismonut
Post by granturismonut »
1995 B16a3 w/8 psi
Garret t3/t4e 57 Trim .63A/R
BMC Race Manifold - log style
Tial 38mm Wastegate
Custom 3" DP
TurboXS RFL Blow-Off Valve
PWR Air-to-Water Intercooler
Walbro 255hp fuel pump
AEM EMS
1988 crx dx
obd0 PS9 ecu tuned with turboedit
450cc dsm fuel injectors
B&M fuel pressure regulator
fuel pressure gauge
walbro 255 lph fuel pump
Garrett t3/t4
Tial 38 mm External wastegate with .6 bar spring
30"x6"x2" intercooler
2.5 inch mandrel bent chargepiping
Greddy Type RS blow off valve
Cusco Catch can
apexi turbo timer
apexi avcr boost controller
Drag exhaust manifold
3” mandrel bent downpipe
3” mandrel bent exhaust
and a couple of other little mods to support whats listed here.
Post by mike93hatch »
the slowest honda around here besides the Werdehausens..
VIDEO:
http://www.midmosr.com/myvideos/mikeshatch.wmv
Engine/Tranny
-Exospeed racing d16 engine
--darton sleeves
--arias 9.0:1 pistons
--eagle h-beam rods
--micropolished crank, etc.
--fully port and polished head
--supertech oversize SS vavles
--supertech valve springs
--supertech titanium retainers
--zex/comp cams 59300 cam
-mishimoto 24x12x3 intercooler
-RLD-FAB SS ramhorn manifold, 3" downpipe, and dumptube
-tial 38mm wastegate (small and big green springs, race valve)
-precision sc34 t3/t4 57 trim .63a/r exhaust, ball bearing and watercooled
-gm 3.0 bar map sensor, LHT map sensor adaptor
-fast-turbo oil line kit
-precision 780cc injectors
-golden eagle vacuum manifold
-aem fuel rail
-hondata thermal intake gasket
-aeromotive fuel press. regulator
-b&m fuel psi gauge
-prothane engine mount inserts
-window welded torque mounts
-walbro 255 fuel pump
-greddy breather catch can
-aluminum radiator
-2300 cfm slim fan
-hallman pro boost controler
-50mm blow off valve
-kteller 3" catback with magnaflow muffler
-kteller 3" test pipe
-msd external coil cap and SS coil
-action 2ms 6 puck clutch
-OBX limited slip differential
-fidanza cv axles
Suspension
-full race traction bar
-dropzone shocks
-suspension technique 2.5" lowering springs
-megan racing aluminum lower control arms with ES bushings
-integra rear sway bar
-Si front sway bar
-lower tie bar
-4 point rear tower bar
Brakes
-brembo discs
-goodridge ss brake lines
-axxis metal master pads
-Si rear disc conversion
Interior
-hondata s300 p28
-plx m-300 wideband gauge
-proform shift light
-autometer pillar pod
-faze gauges (tach, water, boost, oil psi, volts, a/f)
-apexi rev/speed meter
-indiglo gauges
-si door panels rewrapped
-apc racing seats
-short shifter
-prothane shifter bushings
-type r shift knob
-alarm and more
-jvc head unit
Exterior
-front: rota gt3 15" wheels with bfg drag radials
-rear: rota gt3 16" wheels with falken azenis rt-615 tires
-carbon fiber hood with locks
-wings west duckbill
-wings west midwing
-wings west rs sideskirts
-"mugen" front lip
-"type r" rear lip
-"spoon" cf mirrors
-projector headlights
-"vision" corner lights
-red/clear tailights
-vx rear diffuser
