the slowest honda around here besides the Werdehausens..
VIDEO:
http://www.midmosr.com/myvideos/mikeshatch.wmv
Engine/Tranny
-Exospeed racing d16 engine
--darton sleeves
--arias 9.0:1 pistons
--eagle h-beam rods
--micropolished crank, etc.
--fully port and polished head
--supertech oversize SS vavles
--supertech valve springs
--supertech titanium retainers
--zex/comp cams 59300 cam
-mishimoto 24x12x3 intercooler
-RLD-FAB SS ramhorn manifold, 3" downpipe, and dumptube
-tial 38mm wastegate (small and big green springs, race valve)
-precision sc34 t3/t4 57 trim .63a/r exhaust, ball bearing and watercooled
-gm 3.0 bar map sensor, LHT map sensor adaptor
-fast-turbo oil line kit
-precision 780cc injectors
-golden eagle vacuum manifold
-aem fuel rail
-hondata thermal intake gasket
-aeromotive fuel press. regulator
-b&m fuel psi gauge
-prothane engine mount inserts
-window welded torque mounts
-walbro 255 fuel pump
-greddy breather catch can
-aluminum radiator
-2300 cfm slim fan
-hallman pro boost controler
-50mm blow off valve
-kteller 3" catback with magnaflow muffler
-kteller 3" test pipe
-msd external coil cap and SS coil
-action 2ms 6 puck clutch
-OBX limited slip differential
-fidanza cv axles
Suspension
-full race traction bar
-dropzone shocks
-suspension technique 2.5" lowering springs
-megan racing aluminum lower control arms with ES bushings
-integra rear sway bar
-Si front sway bar
-lower tie bar
-4 point rear tower bar
Brakes
-brembo discs
-goodridge ss brake lines
-axxis metal master pads
-Si rear disc conversion
Interior
-hondata s300 p28
-plx m-300 wideband gauge
-proform shift light
-autometer pillar pod
-faze gauges (tach, water, boost, oil psi, volts, a/f)
-apexi rev/speed meter
-indiglo gauges
-si door panels rewrapped
-apc racing seats
-short shifter
-prothane shifter bushings
-type r shift knob
-alarm and more
-jvc head unit
Exterior
-front: rota gt3 15" wheels with bfg drag radials
-rear: rota gt3 16" wheels with falken azenis rt-615 tires
-carbon fiber hood with locks
-wings west duckbill
-wings west midwing
-wings west rs sideskirts
-"mugen" front lip
-"type r" rear lip
-"spoon" cf mirrors
-projector headlights
-"vision" corner lights
-red/clear tailights
-vx rear diffuser
