civicex;296464 wrote:do i only need the coilovers or do i need lower control arms and camber kits or is that only if i lower it to a certain hieght?
to lowers your car all you need is the coilover if thats what you wants.
i suggest you get some brand (budget allowing) of rear lca's because you WILL break the bot(s). if you are in the lucky 1% club with not breaking them you can sell the lca's, but why would you do that. just put them on.
camber kits are not needed to lower your car, but if you want to run stock alignment specs, or close to them, on your car then you would want them.
