gonna drop my car soon so quick question.
02Type-S
Post by 02Type-S »
civicex;296491 wrote:so front lca's are a good idea than i see. should i get oem or aftermarket ones?
Rear LCAs
I didn't get them when I did my Integra, 3 bolts broke, and the stock LCAs were not saveable. Car sat for days until the new ones got delivered.
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
civicex
Post by civicex »
02Type-S;296500 wrote:Rear LCAs
lol so then i should just get all four and save myself the trouble and just stock up on bolts.
PSN: DumbRands
Andrew
Post by Andrew »
I've never broken a front lca bolt, however rears...haha they are almost guaranteed break. Buy some new rear lower control arms a new bolts for the rear and you'll be set.
civicex
Post by civicex »
haha so many mixed answers. let me get some more opinions :P
PSN: DumbRands
Post by Phate »
You shouldn't break a FLCA bolt unless you're being dumb. The RLCA's are always a pain in the ass. The bolts will break off inside of them and that will stop any of your progress.
I've never needed toe/camber arms before, they should be able to get the proper amount of adjustment out of the stock stuff.
Post by HardCore97 »
Phate;296509 wrote:You shouldn't break a FLCA bolt unless you're being dumb. The RLCA's are always a pain in the ass. The bolts will break off inside of them and that will stop any of your progress.
im on all stock stuff and no problems. im not super low, but i took it and had an alignment right after i lowered it. i also got lucky and broke none of the rear bolts, but like i said i soaked them with pb and let them sit before messing with it. but most other people have them break, so it never hurts to be prepared in case one does break. at least that way your car isnt sitting waiting for new parts to arrive
Racecore.com
modthesol
Post by modthesol »
civicex;296464 wrote:do i only need the coilovers or do i need lower control arms and camber kits or is that only if i lower it to a certain hieght?
to lowers your car all you need is the coilover if thats what you wants.
i suggest you get some brand (budget allowing) of rear lca's because you WILL break the bot(s). if you are in the lucky 1% club with not breaking them you can sell the lca's, but why would you do that. just put them on.
camber kits are not needed to lower your car, but if you want to run stock alignment specs, or close to them, on your car then you would want them.
Teg-Potential
Post by Teg-Potential »
civicex;296466 wrote:well i only plan to lower my car maybe 2.5-3 inches and please elaborate what you mean with the toe in or out :P and for the lca bolt is there a good brand that'll last longer than the other?
I know forums are a place for questions.. but have u even googled the idea at all? 2.5 -3in drop is pretty substantianal... 1/2-1in is smal to not much drop btw.. (i think) and alot of the extra pieces.. camber kits/arms etc help to fix the toe as well as ride comfort and tire ware..
dreaming of boost
Making people wealthy by day:
James bond by night
314-452-7933
civicex
Post by civicex »
Teg-Potential;296546 wrote:I know forums are a place for questions.. but have u even googled the idea at all? 2.5 -3in drop is pretty substantianal... 1/2-1in is smal to not much drop btw.. (i think) and alot of the extra pieces.. camber kits/arms etc help to fix the toe as well as ride comfort and tire ware..
yeah i googled it but i couldn't find the answers i wanted.
PSN: DumbRands
02Type-S
Post by 02Type-S »
I've never broken a front LCA bolt
2002 Acura TL-S
